I get this error
Cannot find green and/or pink boxes
Do I need to create boxes with 3rd party image editor or there in in-built feature?
I get this error
Both should work, but I usually use the built-in editor. Did you try using it?
I will check the option and update
It cannot extract text.
I will try again.
Its working.
Thank You so much
