hello everyone, i imported macro as ZIP but the commands i.e. Xclick and visualSearch are unable to find imported images. All images are visible in “Visual” section.
Can you please add a screencast of the situation?
It is searching continuously for the same image. The same macro works fine on Windows 10 remote machine.
It is running on Windows 8.1.
Windows 8.1 is no longer officially supported by us (and Microsoft!) and we never test on it. So this could be a strange bug that shows up in Win8. Officially supported Windows versions are Win7, Win10 and Server 2016/2019.
It is not working on windows 10. The situation and application is same.
So now it stopped working on Win 10? Or is it a different Win 10 machine?
In any case, can you please add a screen video of the macro running? Often this helps us to see what is going wrong.
It is adifferent window machine. the visualsearch command continuously search for the image. The macro is same as above(in screenshot shared). You can refer that screenshot as same issue i am facing.
Ok. But instead of a screenshot, a screen video that shows the macro running would be more helpful to see what is going on.
