"Name": "MACRO NAME",
"CreationDate": "2020-8-13",
"Command": "csvReadArray",
"Target": "csvName.csv",
"Value": "arrName"
"Target": "test string",
"Value": "str"
"Command": "executeScript",
"Target": "function arrSearch(query,arr){ var query = query.trim(); for(var z=0;z<arr.length;z++){if(arr[z].indexOf(query)!==-1){return z;break;}} return-1;} var q=arrSearch(${str},${arrName}); return q;",
"Value": "search"
"Target": "<!--- RESULTS FROM SEARCH ARRAY : ${search}",
Is this post a question or a working demo?
Working demo, a snippet to show it can be done, the full code can’t be disclosed.
The original use case called for looping through a csv and doing a string comparison, searching an array is much faster, so after the search is complete and match is made, the key or index is returned; I used that returned index to get the value arr[index] from the array.
Much faster searching and in my case I removed and unnecessary loop from the json object.
