Hi Community!
How can select a dropdown element by it’s position in the list, not a label which is usually unknown?
Thanks!
Instead of label= use index=
label=
index=
Test macro:
{ "CreationDate": "2018-10-3", "Commands": [ { "Command": "open", "Target": "https://a9t9.com/contact", "Value": "" }, { "Command": "select", "Target": "id=WhatSoftware", "Value": "index=5" } ] }
