I’m wondering if there is a method to have the script simply ignore something if it doesn’t find it and move on.
I’m search a web page, filling a form and asking for a return. The program does this beautifully and will reload the form from the CSV file for multiple records etc. No problem there. Love it…
However, the return for a given entry has a range of potential results in terms of what that returned page will display, after which I’d like to drill down another level.
Let’s say possible page return A may show a Star. Possible Page B return may show a tree and so on.
If I could get the macro to simply ignore an image and continue if it doesn’t see it and then look for the next possible image and so on I could fashion a crude IF THEN ELSE in this fashion.
I’m using the desktop version.
Thank You!
