How can I pass arguments to the macro using bookmarklet javascript?
Hi, what kind of information do you want to send to the RPA software? What would be the use case here?
I ask because the solution depends on what exactly you want to do.
I have server side php script which needs to run the macro at my local computer.
I have seen example of embedding the macro in html page but I want to use the macro stored at my computer.
Here is an idea for a workaround: You can use a very basic embedded macro with only the RUN command inside. And this RUN command can then start any local macro.
And if you need, you can add global variables like
store | Hello World | globalvar1run | your_local_macro
to this basic embedded macro. This way you can pass additional values to the local macros.
Thank you. This workaround will work.
