Hi
Your code is wrong, search in the forum the correct code
"Name": "1",
"CreationDate": "2019-3-23",
"Target": "https://status.ocr.space/",
"Target": "${!URL}",
"Value": "!clipboard"
i did but that was the code that I found and it doesnt work
The code i posted working like a charm.
Please study kantu you can’t claim not to study and know how to use kantu otherwise you pays a professional who makes you the codes.
I studied kanto and built several things until know. I knew that if I will fix that the rest of the code will work fine. I just had a little problem with bigger code:
“Name”: “lawguide beta 4”,
“CreationDate”: “2019-10-26”,
“Target”: “true”,
“Value”: “!ErrorIgnore”
“Target”: “@{!URL}”,
“Value”: “!clipboard”
“Target”: “!clipboard”,
“Command”: “gotoIf_v2”,
“Target”: “{l1counter} > 0",
"Value": "one"
"Target": "0",
"Value": "l1counter"
"Target": "1",
"Value": "l2counter"
"Command": "label",
"Target": "one",
"Command": "storeEval",
"Target": "{l1counter}+1”,
“Value”: “l1counter”
“Target”: “id=SelectCatID”,
“Command”: “select”,
“Value”: “label=פלילי”
“Command”: “clickAndWait”,
“Target”: “xpath=/html/body/div[5]/div[2]/div/div[1]/div[1]/form/input”,
“Target”: “/html/body/div[5]/div[2]/div/div[2]/div[2]/form/div[{l1counter}]/div[1]/div[2]/div/a[1]/span",
"Command": "if_v2",
"Target": "!{!LastCommandOK}”,
“Target”: “link=הבא >”,
“Command”: “storeEval”,
“Target”: "{l2counter}+1",
"Target": "{!URL} ",
“Command”: “else”,
“Target”: “”,
“Command”: “end”,
“Target”: “”,
“Command”: “storeText”,
“Target”: “/html/body/div[5]/div[2]/div/div[2]/div[1]/div[1]/div[1]/div[2]”,
“Value”: “!csvLine”
“Target”: “/html/body/div[5]/div[2]/div/div[2]/div[1]/div[1]/div[1]/div[1]/div[1]”,
“Value”: “!csvLine”
“Command”: “csvSave”,
“Target”: “taltest.csv”,
by the way,
now I have problem with opening the url that was saved in the clipboard. If you could have helped me that could be great
Where do you read this command ?
Can you post the url page with this command please ?
@{!URL} ???
I use this and working
url :
https://www.lawguide.co.il/
thanks to you the store of the url to the clipboard is working
thank you.
now I am trying to open the url that has been saved to the clipboard
but it doesn’t work. it only writes:
https://www.lawguide.co.il/!clipboard
Change your code in this mode and now working
To store/update the value you must use !clipboard
to use the value in your macro you must use ${!clipboard}
“Target”: “${!clipboard}”,
I tried this but its still doing this:
https://www.lawguide.co.il/@{!URL}
writes the the word url.
I want this to save the url first and then open the saved url
I tried this but it doesnt work:
Update your code in this mode
“Target”: “${!URL}”,
