Good morning, I’ve been trying to load a link where the number is a variable, but this variable would have to be loop type.
“Target”: “10596465;10596461;10595940”, – THIS IS THE POINT I DON’T UNDERSTAND
“Value”: “myvar”,
“Description”: “”
http://10.162.102.187:8080/jbpm-console/app/procins.jsf?id=${myvar}&view=token
myvar can only 1 value? I would like to put multiple values , like loop
“Name”: “fim_processo”,
“CreationDate”: “2021-12-30”,
“Value”: “myvar”,
“Description”: “”
“Target”: “http://10.162.102.187:8080/jbpm-console/app/procins.jsf?id=${myvar}&view=token”,
“Value”: “”,
“Description”: “”
“Target”: “linkText=End@POS=4”,
“Value”: “”,
“Targets”: [
“linkText=End@POS=2”,
“xpath=//*[@id="j_id253:0:j_id275"]/a”,
“xpath=//a[@onclick="var a=function(){return confirm(‘Are you sure you want to end this token?’);};var b=function(){if(typeof jsfcljs == ‘function’){jsfcljs(document.getElementById(‘j_id253:0:j_id275’),{‘j_id253:0:j_id275:j_id276’:‘j_id253:0:j_id275:j_id276’,‘xtoken_id’:‘10596124’},‘’);}return false};return (a()==false) ? false : b();"]”,
“xpath=//td[8]/form/a”,
“css=#j_id253:0:j_id275 > a”
“Description”: “”
Tks for help Guys
You can use
“Value”: “myvar${!LOOP}”,
“Description”: “”
To have unlimited var it will be myvar1, myvar2 or you can use a custom name
Hello, the solution actually takes var1, var2 and etc , but doesn’t get the value of var.
/jbpm-console/app/procins.jsf?id=myvar2&view=token
"Target": "9937083,10631685",
"Value": "myvar",
"Target": "http://10.162.102.187:8080/jbpm-console/app/procins.jsf?id=myvar${!LOOP}&view=token",
Your macro code is wrong edit in this mode
"Target": "http://10.162.102.187:8080/jbpm-console/app/procins.jsf?id=${myvar}${!LOOP}&view=token",
You setted in wrong way myvar in url
uiuser
5
“Command”: “executeScript_Sandbox”,
“Target”: “var arr=[“10596465”,“10596461”,“10595940”];\nreturn arr[Number(${!loop})-1];”,
“Value”: “myvar”,
“Description”: “”
“Command”: “prompt”,
“Target”: “${myvar}”,
“Value”: “”,
“Description”: “”
uiuser
6
Thanks a lot for the help. It’s running. below the complete script to help the next ones.
“CreationDate”: “2022-2-10”,
“Target”: “var arr=[“10074189”,“10074284”,“10130411”,“10274439”,“10285611”,“9389929”,“8967747”,“9698443”,“9327095”,“9334259”,“9705652”,“9379555”,“9385580”,“9400316”,“9401794”,“9712214”,“9699241”,“9715686”,“10658045”,“9051392”,“9318285”];\nreturn arr[Number(${!loop})-1];”,
“Value”: “myvar”,
“Description”: “”
“Command”: “comment”,
“Target”: “prompt // ${myvar}”,
“Value”: “myvar”,
“Description”: “”
“Target”: “jbpm-console/app/procins.jsf?id=${myvar}&view=token”,
“Value”: “”,
“Description”: “”
