Hello, im new to this software but i see its pretty powerful.
is there a way to search for multiple images at the same time?
so basically look for these 10 images and if one of them appear click on it.
thanks
You can do with by using Set Errorignore TRUE and then the list of images.
If SeeShell finds the image, it will click it, and if not, it simply moves on to the next command
thanks man thats perfect
