I know this topic has been discussed many times. But may be I have something new.
I am with the new version of the RPA 6.2.2. I don’t know if the problem occured before since I am still testing the product and I am a newbie on ui.vision !
I have this code to retrieve my ip. The website https://api.ipify.org/ returns an only value, the ip :
"Target": "https://api.ipify.org/",
"Command": "pause",
"Target": "5000",
"Command": "storeText",
"Target": "xpath=//pre",
"Value": "ip",
The website https://api.ipify.org/ is sometimes a bit slow to open the page. In this case I have this “open’ failed. No page load event detected after 10 seconds. Error detail: still same ipc secret” error.
So I checked my !TIMEOUT_PAGELOAD which is 55 seconds in the settings. I did as well an echo of the value in the macro and it is definitly 55 sec.
To see the problem I call the same macro (via command line) about 20 times (closing the RPA between but not the browser). In a row, it happens once or two times. Sometimes it works like a charm. It depends on the ipify.org response. So I spent half an hour looking at my screen ![]()
When the macro open https://api.ipify.org/, I see the seconds scrolling (1, 2,…) something like “wait 3s (55)”, with 55 the timeout_pageload. So usually it succeeded, but when the page has some difficulties to open (the Firefox is waiting : with an hourglass in the tab), seconds pass and at “wait 11 sec. (55)” the error happens.
So no matter the value I have in !TIMEOUT_PAGELOAD, there is “another” time out (which one ?) of 10 seconds. The only 10 seconds I have is !TIMEOUT_WAIT which is not supposed to interfere.
So I have the feeling that !TIMEOUT_PAGELOAD is not doing its job. When the website is slow, I have nothing in the page so for sure the page is not loaded.
So if it is a bug it is a bit annoying because 10 seconds it is short. In this case the problem will be easy to reproduce (with a very slow website or even with : https://api.ipify.org/.)
But probably it is a newbie mistake, so enlighten me ! Because it is really blocking…
Thanks.
Eric.
