I try Kantu fo Chrome for the first time and probably fasing some bug.
I fill some form and on the next page testing by assertText if that printed text is correct. For some strings it works, but it seems not working with strings with diacritics characters (ěščřžýáíé).
[info]
Executing: | assertText | //*[@id="edit-order-summary-summary"]/div/div[1]/table/tbody/tr[2]/td[2]/div/div | T-shirt |
[info]
Executing: | assertText | //*[@id="edit-order-summary-summary"]/div/div[2]/div/div/div[2]/span[2] | 2 Kč |
[error]
text not matched,
expected: "2 Kč",
actual: "2 Kč"
[info]
Macro failed (Runtime 19.62s)
String in macro is copied from a site, so it really is exactly the same (no difference in whitespace, etc.).
