I’m taking two desktop screenshots via CaptureDesktopScreenshot
A before and after state if you like and I want to compare the two images in a repeatIf statement
Any ideas how I can reference these images?
Pat
Pat
What does it mean to compare 2 images?
What do you have to do?
Thanks for getting back to me…
I’m basically taking a “before” screenshot and later in the process I’m taking an “after” screenshot.
At the end of a loop I want to compare the two images to see if they are the same or if they’ve changed. If they’ve changed I Want to repeat the loop, If they haven’t changed I want to exit the loop
Pat
You’ll probably have better stability using something like verifyElementPresent or combine your macro with an API that does that: https://stackoverflow.com/questions/39768788/api-to-compare-similarity-between-two-images
Thanks - I’ll look into it
What kind of change do you expect? In other words: What are you watching? A website text, some layout changes or…?
I’ve found another way of doing what I need which will be a bit more robust.
I’m building a desktop automation macro. I was looking for layout changes in a desktop application - the API suggestion @User9898 came up with would probably work out for what I needed…
Pat
