ClientException: Failed to fetch
It doesn’t happened before
You might have encountered an issue with the most recent OCR API update. Can you report more details? Then we can fix it ASAP.
=>If you test the connection with Postman, do you get the same result?
You probably know it, but just in case: Postman is a free app.
If you see the problem even with Postman, a screenshot of the result could be helpful.
PS: Currently updated endpoints are:
  • FREE Endpoint
  • PRO2 Endpoint
The PRO1 Endpoint is not updated yet. We will update this endpoint in a few weeks, once we are sure there are no unintended side effects with the update that escaped our QA.
