Hi there, I’m currently trying to use XType as a replacement method for the sendKeys command, as a website I use (Discord) doesn’t really function using the other one. Here’s a simple script to test how it works and I had no success:
“CreationDate”: “2018-10-27”,
“Target”: “hi - Google Search”,
“Target”: “id=rhscol”,
“Command”: “XType”,
“Target”: “"hi"”,
“Command”: “XType”,
“Target”: “${KEY_ENTER}”,
The XType commands do not work at all, the “hi” is not typed and the enter key is not used. Is this not how the XType commands are intended to work? Am I missing something on my end? Thank you!
