Why writes No data returned.
Can you please add a screencast of this situation? Otherwise I have no idea what this could be.
So I see that you are using QTranslate, which uses the free OCR API. The API is currently up and running fine: https://status.ocr.space/
Some questions:
- Do you still get the error?
- If yes, do you get the error only for some images or for all?
