Hi!
I’d like to run a test with UI.Vision on a webpage and I`d like to freeze and advance time of methods like setTimeout.
This is possible to do with Cypress through cy.clock() and cy.tick().
For instance, this guy on YouTube use cy.clock() and cy.tick() to pause a canvas animation every 1500ms and see how it looks like.
(1) Is there a way around to do this without Cypress, using just UI.Vision? Would it be able to do through the command “executeScript” of UI.Vision? How could I do that?
(2) I thought also that maybe I could somehow import the commands of Cypress and use them on UI.Vision. Is that possible? How could I do that?
(3) Maybe I could use this code from Github here. But how do I apply this code on UI.Vision? Can I use the command “executeScript”? For instance, even the Console from Chrome don’t recognize the command describe() when I try to copy the code.
If someone could teach me how to this I`d be very grateful. Thank you!
