Can not find anywhere how to press cancel on ctrl+p screen while using macro. Any ideas?
Kantu - just like any other browser extension - can not press ctrl+p or any other system shortcut.
But SeeShell Desktop Automation can do this easily
=> There you can just use
Type ^p (^ is for the Ctrl key)
Okay I see, thank you will have a look into it.
Update: Meanwhile Kantu can press Ctrl+P with the new xtype command.
With today’s update, xtype can also simulate the ESCAPE key to cancel the print dialog.
