After the latest update, the command gotoif are changed in gotoif_v2 and gotoif_deprecated.
With the gotoif_v2 i get the error * Error in condition of gotoIf_v2: Unexpected identifier. The target is: “${product}” == “text” the value is text.
Any suggestions on this?
In the new V2 versions of these commands you need to remove the"" around the variables.
So instead of
use
${product} == “text”
Hi Ulrich, thnks for the reply. I figured this out yesterday
Another issue i have with the latest update is that the script just stops at a certain position en don`t go any further. I have to stop the script and run it again.
I hate the new version, everything just get worse than the older one. All script break and even after correcting the deprecated, it still can’t run smoothly. How can I downgrade ?
If you can give us examples on what does not work, we can fix it. Just saying “does not work” does not help us.
See Page Not Found
@PHC " latest update is that the script just stops at a certain position en don`t go any further. I have to stop the script and run it again."
Do you have a test case for us?
Hello, at the moment i dont have a testcase. The scripts i run are running on a verified logged in site.
I keep you updated if it happens again.
I have a example where the visual search and Xclick doesn`t work. I want to send te screencast link but not in public forum.
Please send it to team AT ui.vision
I allready found te reason. I work with 3 screens. If i make the macro and the xclick image and i run the script on another screen then the image is not found. So Kantu takes only a screenshot from the primary screen, but when i run the script on another screen it cannot find the image, while it is in the Visual folder.
