I was using if in Chrome; exported my script to import it into Firefox to find that all my if’s got renamed to if_v1_deprecated and my while to while_v1_deprecate.
I changed that from if_v1_deprecated to if_v2 to get the script to work in Firefox… but got stuck on:
Setting file path fo file inputs is not supported by Firefox extension api yet
… a little typo “fo file” should probably read “to file” (I think) ![]()
So now I am back in Chrome… but what should I use? Should I keep my if’s as is, or rename them to if_v2?
Thank you!
