I have the following setup:
Windows 11 Enterprise v. 23H2 OS v. 22631.5768
Chrome v. 136.0.7103.93 (64 bit)
Chrome extension UI.Vision 9.5.3
IT support on my work helped me log in as admin and installed the latest version of xmodules (uivision-xmodules-setup-v2024.exe )
But the Chrome extension won’t detect xmodules.
I have tried to click on test it, tried to add and remove the extension.
I have also with the help from IT support tested to install via the zipfile and running the 1install.bat file, with no luck.
I saw that many people had this problem in the past. What is the status of this bug?
