I am launching Edge version 101.0.1210.53 via a batch file on the task scheduler on windows 10 to launch UI RPA 7.0.11 browser extension.
Macro opens website
Pause 20 seconds
enter value 1
Enter value 2
Click submit
Pause 20 seconds
Click link 1
UI RPA just enters 2 values into a login box then clicks a link.
If an instance of Edge is open the RAP fails with the error “Invalid tab ID: 20 (number always changes).
I have seen a few work arounds and advice on this, but they do not work for me. Putting sleep into cli script after before launching macro for example.
The only way I can ensure UI RPA runs without the error is:
- close the browser
- open browser
- click on UI RPA extension to open it
- close the browser but leave RPA UI window open
- cli script and macro run without issue.
This is annoying though. I hope that the above description of the fix will give one of you lovely people a hint as to how I might fix this issue.
Thanks for reading and have a lovely day.
Pat
