I can’t switch to a modal window for entering text in a text field.
Example in the screenshot …
I don’t understand how to set this window so that the text is inserted.
Comand: type
Terget: id = modal-add-publication
does not work
Do you have a link to the website?
But what will work for sure is to use XClick (to set the focus on this window) and then XType to enter the text.
I have the same problem with modal windows. I have tried all X- methods, click, clickat, and more.
and 18 months later… same problem ![]()
I’m thinking there should be a UI.vision company “Modal Hackathon”, perhaps?
