Is there a way to add timestamp within screenshot?
You first generate todays date and put it into
${mydate}:{
“Command”: “echo”,
“Target”: “Generate TODAYs date in in YYYY-MM-DD format “,
“Command”: “storeEval”,
“Target”: “var d= new Date(); var m=((d.getMonth()+1)<10)?‘0’+(d.getMonth()+1):(d.getMonth()+1); d.getFullYear()+”-”+m+”-"+d.getDate();",
“Value”: “mydate”
Then you add
${mydate}to the screenshot name:{
“Command”: “captureEntirePageScreenshot”,
“Target”: “article_${mydate}”,
Thanks mate. I’ll give it a go.
