I have installed modules from zip file but ScreenCapture module is not available.
Any idea how to solve this?
Thank you.
Tom
Thank you.
Tom
I have some questions:
Are the other XModules installed ok?
If you use the EXE, does it work ok then? (Or you can not use the EXE for some reason?)
In any case, the ScreenCapture module is only “nice to have” during macro creation. It is not required for the visual features to work.
Other XModules were installed and tested. I was running .bat files from command line.
It’s not that I need it. Everything is runnig fine without it. I am just wondering why…
