Hey Guys, hope you can help me!
I got a problem with my script/program. I have a script that makes a form, and when the form is generated is opens a new tab. After the first script(form-create script) is done, it then runs another script, that should fill the form. Both script works fine by them self, if i run them independently.
The problem is that when the secund script should run, it tries to run on the form-creating tab, but it should run on the new tab, where it should fill out the form.
Thanks if you have read so far!
