Hi everyone
I’m having a problem with my Kantu up 5.0.1 version
Command: Open
Target : https://www.example.com/xyz/${!COL1}
Error: open’ failed. No page load event detected after 10 seconds.
my solution
Using selectWindow and open page in new tab ← this works !!!
Using pause or waitForPageToLoad after command open does not work!!!
“!errorIgnore” = false ← It also doesn’t work
Error does not always occur !!!
admin
June 12, 2019, 2:33pm
2
Please try again with V5.0.3, as this version fixes an issue with the OPEN command. Please let me know if this solves the problem for you.
At the moment I have 5.0.3 version. BUG still exist
Browswer newest Chrome 75.0.3770.80 I checked two machines win10 32bit and 64bit. Doesn’t difference.
It’s better when:
-close another tab
-reload browser
but its only my speculations.
Works only when i open site in new tab (Kantu command <- selectWindow)
admin
June 12, 2019, 9:57pm
4
Do you have a test macro for me? Ideally also a screencast that shows this error.
I have 3 tabs witch the same subdomain or I started macro in this same domain. And not working!!!
But i start kantu another domain, then everything is ok.
I rewrite my macros to using new command while_2 and executeScritpt <- not changes
Maybe selectWindow will help you for a while?
definitely
but the error still exists
I keep my fingers crossed by ui.vision development team
I actualize my kantu to actual version 5.0.5.
And this bug still exist
I remind you about the problem
This bug is exist for me as well !
I’m also experiencing this in 5.1.9
dapgo
September 12, 2019, 2:26pm
12
Same behaviour, and as workaround I went back to version 4.2.7
[error] open’ failed. No page load event detected after 10 seconds. Error detail: still same ipc secret
Addon: UI.Vision Kantu for Chrome 5.1.9
Webbrowsers: Firefox 69.0, Waterfox 56.2.14
admin
September 23, 2019, 6:19pm
13
A test macro or a screencast of this issue would be helpful for us, so we can recreate the issue on the test systems.
acajoo
October 23, 2020, 11:08am
14
I stumbled on this error too, here’s the screencast…
My setup:
UI.Vision RPA 5.8.8
Google Chrome version 86.0.4240.111 (Official Build) (64-bit)
Windows 10 Pro 64-bit
Intel Core i5-6300U
16GB RAM
Problem occurs when already loaded page in the tab is the one we want to load…
admin
October 29, 2020, 12:10pm
16
@acajoo Does this happen with any website or “only” the one from the screencast?
As a workaround, does adding REFRESH after the open command help?
I think the problem can be # in url try with url without # in url
# can block the loading of url
