Hi Guys,
i’ve some trouble with small pictures with digits.
This picture with the number “1” inside, can not be analyzed with version 1 and version 2 does not accept the file.
If i use a picture with the number “11”, the version 1 of the ocr works successfully, but version 2 still does not accept the file.
Whats wrong with my files?
Regards,
Markus
admin
2
Engine 1 has indeed troubles finding single digits. I confirmed that the images are too small for engine2.
Solution: if you enlarge the images e. g. by 600% they work well with engine2:
Update 2023: Another good OCR software for single-digit number OCR is the new OCR engine5.
OCR Engine5 returns the numbers correctly even without additional enlargement:
Update: OCR Engine5 is now part of Engine2.
admin
6
Update 2026: Clearly the best OCR software for single-digit number OCR is the new OCR engine3.
