(i’m using kantu for about 5 months but learn by myself with no code skills)
my case is I fill a code in a box, the website will show 1/5 results. I want to store the result, but can’t because the text of result always there, the results are hidden. Any suggestions? Thanks so much in advance. (sorry for my explaination, I don’t know how to write in Code langages)
A screenshot of the situation would be helpful for us to understand
Have a look at the storeText command, this should work fine here. For a list of all data extraction options, see the list of web scraping commands.
If you have troubles finding the right locator for storeText, try OCRExtractRelative, with a green and pink box as indicated here:
This will OCR the part inside the pink area.
thanks so much for your help. Best wishes to you
thanks so much. your way is easy, extremly helpful and work for me that’s what I need. Thank you again.
