I’m obviously doing something wrong with !LastCommandOK. I have also tried {
“Command”: “if_v2”,
“Target”: “${LastCommandOK} == true”,
but no luck.
“Command”: “if_v2”,
but no luck.
Your code have an error
You must use this command
{ "Command": "if_v2", "Target": "${!LastCommandOK}", "Value": "" },
To reverse you must use !
{ "Command": "if_v2", "Target": "!${!LastCommandOK}", "Value": "" },
