Unable to convert csv File into a HTML file using javascript code using executescript_sandbox
ERROR I got is
[error]
Line 31: document is not defined
command : executescript_sandbox
Target:
document.getElementById(“file-input”).addEventListener(“change”, function(event) {
var file = event.target.files[0];
var reader = new FileReader();
reader.onload = function(event) {
var csvContent = event.target.result;
processCSVFile(csvContent);
reader.readAsText('./reports.csv', 'utf-8');
function processCSVFile(csvContent) {
var rows = csvContent.split(“\n”);
var htmlTable = “
htmlTable += “
Report Status ”;
for (var i = 0; i < rows.length; i++) {
var row = rows[i].split(",");
htmlTable += "<tr>";
for (var j = 0; j < row.length; j++) {
htmlTable += "<td>" + row[j] + "</td>";
htmlTable += "</tr>";
htmlTable += "</table>";
// Do something with the HTML table
console.log(htmlTable);
value: javascript
ulrich
May 30, 2023, 10:58am
2
pavanig:
executescript**_sandbox** can not access anything on the website. Use executescript instead.
Hi ,execute script is not working too. Please provide working examples to execute javascript and html program.Thank You!!
Line 36: Error in executeScript code: require is not defined
var fs = require(“fs”);
fs.readFile(“./reports.csv”, ‘utf8’, function(err, csvContent) {
if (err) {
console.error(err);
return;
var rows = csvContent.split("\n");
var htmlTable = "<table>";
htmlTable += "<h3> Report Status </h3>"
saveFile("report.html", htmlTable);
function saveFile(filename, data) {
fs.writeFile(filename, data, function(err) {
if (err) {
console.error(err);
} else {
console.log(filename + " saved successfully.");
