Icon is just gone?
App is enabled – I don’t want to uninstall now and reinstall coz I don’t have the actual macros I created.
Where can I find my macros in the file systems to go and copy them and then try and uninstall and then reinstall?
Icon is just gone?
Did you maybe use the “hide in chrome menu” function? If so, you find the icon now in the Chrome menu (click the 3 dots to show it):
In the default HTML5 storage the macros are stored inside Kantu and would be lost if you just uninstall. So it was very good that you did not uninstall ![]()
Once you fix this issue, I highly recommend that you make regular macro backups and/or use the hard-drive storage option, see also /rpa/x/Modules add click, type, drag and drop with native events, file access, and Robotic Process Automation (RPA)
Awesome – That fixed it! Thank you1
