Is there a way in powershell to completely shut down Chrome, kill all the process to stop the memory leak problem?
I tried Taskkill /IM chrome.exe /F, that doesn’t solve the problem.
I suggest you to close browser periodically before uses all memory and reopne it
I did use the command up there to close chrome but it didn’t work, what exactly do you recommend so I could follow?
If closing with the API use the argument: closeBrowser=1
You should never force close a browser killing the task. You take a chance on corrupting settings, cache, logs, etc. For example, with PowerShell you can use:
Get-Process -Name namehere | ForEach-Object { $_.CloseMainWindow() }
Thank you, could I ask, in this case, I want to close Chrome, what do I put in *name here *?
And what else do I need to custom in your line of command you just give me?
The process is chrome
If you do Get-Process you’ll get a list of running processes on your machine
I use the same as in this RPA script:
taskkill /F /IM chrome.exe /T
@kolor_blind You can use deleteCookies then selectWindow | TAB=Close in RPA script after completing execution
Dear @ulrich, this didn’t work. Eventually, after a few run times, the no tab with id error appears.
The only thing that would work, is restart my VPS. But here the thing:
This no tab with id error is a huge pain. I don’t know what to do anymore.
@Kaushal_25 the deleteCookies is also a command in RPA, right?
yes deleteCookies is also uivision command
Works for me in V6.33 just fine. What is not working?
