Hi, I have a pretty unique setup and I want to install Xmodules, but the Appimage won’t work for me; I likely need to install Xmodules manually.
I have a docker container (ubuntu, 18) running on Windows (WSL 2). I can’t use Appimage because I can’t use FUSE; There’s no kernel to insert modules into.
I’ve tried:
- Mounting the appimage (can’t mount)
- Extracting the files and attempting to run manually (
--appimage-extract; linux - How can I extract files from an AppImage? - Super User)
So now I’m trying to figure out where to place the files manually to install them.
Can you tell me where to place the files from the AppImage?
In the mean time I’ll try to figure out the install script.
Thanks.
