Hi.
I am not sure if this is possible, but it would be amazing if you could export a variable directly via LocalStorageExport without the need to go via the csv route
Also it would be very helpful if it was possible to choose the file path where the file is saved to
Thank you for your help.
Best wishes
Anselm
