after using SetProxy command for 5 ip addresses, the command is being ignored due to limit, this command is it free to use or needs a license for more than 5 ip addresses ?
Yes, for more then 5 changes you need a PRO (or higher) license.
Update: For U.Vsion V9.1.9 and higher there are no more limits on setProxy ![]()
