sure this is the macro
“Name”: “test”,
“CreationDate”: “2023-10-30”,
“Command”: “csvReadArray”,
“Target”: “treads.csv”,
“Value”: “treads”,
“Description”: “”
“Command”: “bringBrowserToForeground”,
“Target”: “”,
“Value”: “”,
“Description”: “”
“Target”: “https://codeimg.io/”,
“Value”: “”,
“Description”: “”
“Target”: “xpath=//[@id="__BVID__84"]/div/div/div/div[2]/div/img",
“Value”: “”,
“Targets”: [
"xpath=//[@id="__BVID__84"]/div/div/div/div[2]/div/img”,
“xpath=//div[2]/div/img”,
“css=#__BVID__84 > div > div:nth-child(1) > div > div:nth-child(2) > div > img”
“Description”: “”
“Target”: “xpath=//[@id="_BVID__77___BV_modal_footer"]/div/div/div[2]/button",
“Value”: “”,
“Targets”: [
"xpath=//[@id="_BVID__77___BV_modal_footer"]/div/div/div[2]/button”,
“xpath=//div/div/div[2]/button”,
“css=#_BVID__77___BV_modal_footer > div > div > div:nth-child(2) > button”
“Description”: “”
“Command”: “forEach”,
“Target”: “treads”,
“Value”: “tread”,
“Description”: “”
“Command”: “XClickRelative”,
“Target”: “gfjrzr_dpi_96.png”,
“Value”: “”,
“Description”: “”
“Command”: “XType”,
“Target”: “${KEY_CTRL+KEY_A}”,
“Value”: “”,
“Description”: “”
“Command”: “XType”,
“Target”: “${tread[1]}”,
“Value”: “”,
“Description”: “”
“Target”: “xpath=//[@id="app"]/div/div/header/div/div/div[3]/button",
“Value”: “”,
“Targets”: [
"xpath=//[@id="app"]/div/div/header/div/div/div[3]/button”,
“xpath=//div[3]/button”,
“css=#app > div > div > header > div > div > div:nth-child(3) > button”
“Description”: “”
“Command”: “pause”,
“Target”: “3000”,
“Value”: “”,
“Description”: “”
“Target”: “unb43p_dpi_96.png”,
“Value”: “”,
“Description”: “”
“Command”: “pause”,
“Target”: “1000”,
“Value”: “”,
“Description”: “”
“Command”: “executeScript_Sandbox”,
“Target”: "return ${tread[0]}.slice(0,10) ",
“Value”: “name”,
“Description”: “”
“Command”: “XType”,
“Target”: “C:\Users\owner\Documents\treads\${name}${KEY_ENTER}”,
“Value”: “”,
“Description”: “”
“Command”: “pause”,
“Target”: “1000”,
“Value”: “”,
“Description”: “”
“Target”: “xr7qhv_dpi_96.png”,
“Value”: “”,
“Description”: “”
“Command”: “end”,
“Target”: “”,
“Value”: “”,
“Description”: “”
an example csv file that would not work
“Introduction, Data types in JavaScript
are fundamental for coding. Let’s explore key data types and their code representations! #DataTypesInJavaScript #IntroToJavaScript #ExploringDataTypes #FundamentalCoding #CodeRepresentations #KeyDataTypes #JavaScriptBasics”,“// Let’s dive into data types
“String, Strings represent text in JavaScript. You can define them using single or double quotes.”, “const myString = ‘Hello, World!’;
#JavaScript”
“Number, Numbers represent numeric data. They can be integers or floating-point.”, “const myNumber = 42;
#JavaScript”
“Boolean, Booleans represent true or false values. They are often used for conditions.”, “const isTrue = true; const isFalse = false;
#JavaScript”
“Undefined, When a variable is declared but not assigned a value, it is undefined.”, “let myUndefinedVariable;
#JavaScript”
“Null, Null represents an intentional absence of any object value.”, “const myNull = null;
#JavaScript”
“Object, Objects are key-value pairs and are used to store structured data.”, “const myObject = { name: ‘John’, age: 30 };
#JavaScript”
“Array, Arrays are ordered lists that can hold multiple values of different data types.”, “const myArray = [1, ‘apple’, true];
#JavaScript”
“Function, Functions are reusable blocks of code. They can take parameters and return values.”, “function greet(name) { return Hello, ${name}!; }
#JavaScript”
“Symbol, Symbols are unique and immutable data types, often used as object property keys.”, “const mySymbol = Symbol(‘description’);
#JavaScript”
“BigInt, BigInts are used for working with large integers beyond the range of regular numbers.”, “const bigNumber = 1234567890123456789012345678901234567890n;
#JavaScript”
“Object, Objects are used for storing structured data with key-value pairs.”, “const person = { name: ‘Alice’, age: 25 };
#JavaScript”
“Typeof Operator, The typeof operator helps you determine the data type of a value.”, “const typeOfString = typeof myString; const typeOfNumber = typeof myNumber;
#JavaScript”
“Type Conversion, You can convert data between different types using various methods.”, “const numberToString = String(myNumber); const stringToNumber = Number(myString);
#JavaScript”
“Coercion, JavaScript performs type coercion to convert values to the same type for operations.”, “const addition = 5 + ‘5’; // Result is ‘55’
#JavaScript”
“NaN, NaN stands for ‘Not-a-Number’ and represents an unrepresentable value.”, “const result = ‘Hello’ / 2; // Result is NaN
#JavaScript”
“Truthy and Falsy Values, JavaScript has truthy and falsy values, which are not explicitly true or false.”, “const truthyValue = ‘Hello’; if (truthyValue) { /* This code will run */ }
#JavaScript”
“JSON, JSON (JavaScript Object Notation) is a format for exchanging data, often used with APIs.”, “const jsonExample = ‘{"name":"John","age":30}’”;
#JavaScript"
“Date, Dates are used to represent dates and times in JavaScript.”, “const currentDate = new Date();
#JavaScript”
“RegExp, Regular expressions are used for pattern matching and text manipulation.”, “const regex = /pattern/;
#JavaScript”
“Global Object, The global object represents the global scope and contains built-in functions.”, “const pi = Math.PI; // Accessing Math from the global object
#JavaScript”
“Promises, Promises are used for asynchronous operations and provide a cleaner alternative to callbacks.”, “const promise = new Promise((resolve, reject) => { /* Your async code here */ });
#JavaScript”
“Set and Map, Set and Map data structures provide unique values and key-value mappings, respectively.”, “const mySet = new Set([1, 2, 3]); const myMap = new Map([[‘a’, 1], [‘b’, 2]]);
#JavaScript”
“Custom Objects, You can create custom objects with your own properties and methods.”, “class Dog { constructor(name) { this.name = name; } bark() { console.log(${this.name} says woof!); } }
#JavaScript”
“Wrapping Up, Data types are the building blocks of JavaScript. Master them, and you’ll become a coding ninja!
#JavaScript”,“
// #JavaScript”
