ubuntu 18.04
Version 68.0.3440.106 (Official Build) (64-bit)
if error in code, then code gets wiped ![]()
see the video
I was using this code:
Users must write code elsewhere while testing Kantu code?!
see the video
Yeah, the “disappearing code” is a bug that will be fixed asap, the code should not disappear.
But I can also tell you what is wrong with the code snippt: If you copy JSON from forum text (and not from the code box!), it gets the wrong ".
Wrong: “”, as in “Commands”:
Correct: "" as in "Commands":
=> you need to do a search & replace with the correct ones before pasting it in the Kantu JSON source code editor.
re: bug
understood
re: copy /paste code
Thanks for the heads up!
