I noticed that the icon on the application bar hasn’t changed, can you change it?
Which icon? Can you pls add a screenshot?
OS: Windows 10 (build 1809)
Kantu: 5.0.3
FileAccess XModule: 1.0.6
RealUser XModule: 1.0.12
DesktopAutomation XModule: 1.0.19
Maybe re-installing XModules will work.
You can try this:
# How to reset the icon cache database on Windows 10
In windows 7 it’s the same old icon remained in menu windows
Try this and also re-installing / updating XModules.
# Purge and rebuild the Icon Cache in Windows 8/7
I have already installed the last xmodules version
And also purged icon cache ? C’mon, use more words, help me. :)))
It’s not that. They have not replaced logo.png in the extension folder. Copy logo128.png to logo.png and you’ll get a new icon.
Chrome:
C:\Users[user]\AppData\Local\Google\Chrome\User Data\Default\Extensions\gcbalfbdmfieckjlnblleoemohcganoc\5.0.3_0
Firefox: You get the idea.
In replaced profile on the right.
