How should I know rate limit per hour for each package?
Free user Api probably 150 per hour (3600 sec) After 1 hour will can use it again.
I want to make sure if I choose pro plan and this issue willl be solved. Could you help me for this issue?
The PRO and PRO PDF plans have a much higher rate limit.
The PRO plan includes 300,000 conversions per month, these are ~7 conversions per minute. To allow for peaks, the systems allows for up to 60 conversions (pages) per minute (= one per second).
And if this is not enough, please contact us and we will try to find a solution.
Could I know rate per hour for PRO plan? Does it reach up to 300 - 500 per hour?
I understand that 60 cons/min is not equal to 3,600(60 x 60) cons/hour. It’s cause of 300,000 cons/month.
I would like to make sure that I can use api more than 150/hour for peaks?
(403) limit per hour
Best Regards,
No problem at all ![]()
