I used Command Line API for Firefox to run a macro. Something like “file:///C:/test/ui.vision.html?macro=myMacro&closeRPA=1&closeBrowser=1&direct=1”
It work most of time. But some time it open a pop up with Save/Discard popup for untitled macro (attached screenshot). This is really annoying and it stop running the targeted macro.
How can I fix that? or just set to auto discard the untitled one and keep Runing the named macro as Command Line sent.
Thanks much!
Did you press Cancel once? That should fix it.
yes I did over and over again. As you can see in the screenshot. The pop up say Untitled. But behide it is full code of myMacro that should be played from Command Line API. There is NO untitled document in here to Save.
Ok, we will debug this further and fix it asap.
