Hi! That is an interesting question!
I think your proposed solution “store the variable of last current id” is exactly right. And the way to do this is to use a global variable.
I modified the DemoCsvReadWithWhile accordingly. The new code is marked with red. Now, you can stop the macro and restart it, and it will continue with last line that was not yet submitted (= the macro start and stop “simulates” the unreliable website in your case). The global var is used to set !csvReadLineNumber to the right value (= the line number to read).
Just one thing to note, before running the main macro, you need to run this one line macro here once, so that the global variable is defined:
"CreationDate": "2018-9-17",
"Target": "0",
"Value": "GLOBAL_LAST_LINE_READ"
Main macro:
“CreationDate”: “2018-9-17”,
“Target”: “180”,
“Value”: “!timeout_macro”
“Target”: “fast”,
“Value”: “!replayspeed”
“Command”: “comment”,
“Target”: “Add resume feature”,
“Command”: “if”,
“Target”: “${global_last_line_read} > 0”,
“Target”: "${global_last_line_read} ",
“Value”: “!csvReadLineNumber”
“Command”: “endif”,
“Target”: “”,
“Target”: “The file ReadCSVTestData.csv is pre-installed with Kantu.”,
“Command”: “csvRead”,
“Target”: “ReadCSVTestData.csv”,
“Command”: “echo”,
“Target”: “Status = ${!csvReadStatus}, line = ${!csvReadLineNumber}”,
“Command”: “while”,
“Target”: “"${!csvReadStatus}" == "OK"”,
“Target”: “${!csvReadLineNumber}”,
“Value”: “global_last_line_read”
“Command”: “echo”,
“Target”: “status = ${!csvReadStatus}, line = ${!csvReadLineNumber}”,
“Target”: “Sample Sign-Up Form”,
“Command”: “type”,
“Target”: “name=entry.933434489”,
“Value”: “${!COL1}_${!csvReadLineNumber}”
“Command”: “type”,
“Target”: “name=entry.2004105717”,
“Value”: “${!COL2}”
“Command”: “type”,
“Target”: “name=entry.1382578664”,
“Value”: “${!COL3}”
“Command”: “clickAndWait”,
“Target”: “//*[@id="mG61Hd"]/div/div[2]/div[3]/div[1]/div/div/content/span”,
“Command”: “storeEval”,
“Target”: “${!csvReadLineNumber}+1”,
“Target”: “true”,
“Value”: “!errorIgnore”
“Command”: “echo”,
“Target”: "Reading CSV line No. ${!csvReadLineNumber} ",
“Target”: “false”,
“Command”: “endWhile”,
“Target”: “”,
