I found the !csvLine unclear as to how you write to the next line within your saved csv. I realized that each save started a new line. I also couldn’t find an example of looping through a csv, doing something with that variable, then writing to a new csv based on that line.
This script will go through each line in ‘currency-names.csv’, find the USD converted rate via xpath, save that value to a new csv called csvreadwritetest. currency-names.csv is a single column with values:
EUR
CNY
INR
BTC
"Name": "DemoCsv_Loop_Read_Write_Save",
"CreationDate": "2019-6-24",
"Target": "fast",
"Value": "!replayspeed"
"Target": "https://a9t9.com/kantu/demo/csvsave",
"Target": "currency-names.csv",
"Value": "csvFile"
"Command": "csvRead",
"Target": "${csvFile}",
"Value": "csvFile"
"Target": "Status = ${!csvReadStatus}, line = ${!csvReadLineNumber}",
"Command": "while",
"Target": "\"${!csvReadStatus}\" == \"OK\"",
"Target": "${!COL1}",
"Value": "!csvLine"
"Command": "storeText",
"Target": "//tbody/tr/th[2]/a[text()='${!COL1}']/following::a[text()][1]",
"Value": "c2"
"Target": "${c2}",
"Value": "!csvLine"
"Target": "Currency ${!COL1} is ${c2} when converted to USD.",
"Value": "!csvLine"
"Value": "!csvLine"
"Command": "csvSave",
"Target": "csvReadWriteTest",
"Command": "storeEval",
"Target": "${!csvReadLineNumber}+1",
"Value": "!csvReadLineNumber"
"Target": "true",
"Value": "!errorIgnore"
"Target": "Reading CSV line No. ${!csvReadLineNumber} ",
"Target": "false",
"Command": "endWhile",
