Need information on integration ui vision automation scripts with testRail
Hi, what exactly do you want to achieve? Import test results data into Testrail?
1.We want to link automated test scripts in UI Vision to specific test cases in TestRail.
2.We want to transfer test execution results from the UI Vision tool to TestRail. This integration has to provide
real-time visibility into test execution progress, allowing us to monitor the status of tests, track defects, and generate comprehensive test reports.
3.And the Test Results has to integrate with JIRA to Report Defects on Failed Test Scripts
@admin, I am looking forward to hearing back from you.
