Hi, how to drag & drop a few commands? I don’t know how to select more than 1 blocks…
You can’t, it’s one at a time
Yes, this is not supported yet. But as workaround I recommend the source code tab: Since the source code tab contains plain text, you can easily copy and paste several lines at once. You can use “Jump to source code” feature to go directly the selected line:
