Good afternoon,
I can’t make the loop read the variables.
In the example there are 2 but then I will put hundreds.
“Target”: “/jbpm-console/app/procins.jsf?id=myvar${!LOOP}&view=token”,
It doesn’t read the variable in loop. What am I doing wrong ?
Thank you for your help
"Target": "9936644;9937083",
"Value": "myvar${!LOOP}",
"Command": "comment",
"Target": "echo // myvar${!LOOP}",
"Target": "/jbpm-console/app/procins.jsf?id=myvar${!LOOP}&view=token",
