Hi @admin
Why do not add a search and replace fields in json code macro of ui vision ?
It’s very hard to scrool all macro code and read all line and replace manually
A search and replace in macro code json will be appreciates.
Here image
Hi @admin
Here image
A search and replace function in json part of ui vision is it very useful do you plan to add it?
Do you think this is not a good idea ?
Yes, I think it is a good idea. I created a ticket for it
Workaround: What I do if I need to mass-replace some code is to copy and paste the JSON source code into an app like Notepad++ , do the search and replace there, and then copy the JSON code back into the UI Vision IDE.
Thanks admin I use notepad++ but it more fast search and replace directly in json area
Very good Idea. I was going to introduce as suggestion when I saw it here. Very cumbersome to copy into another app then do search replace then copy back.
