I use a csv to form fill and always after executing about 3 lines, I get this error.
[error] fail to inject
I remove the three already executed lines from csv and it works fine for another three lines.
Please find below the code. TIA.
“Command”: “csvRead”,
“Target”: “mails.csv”,
“Command”: “while”,
“Target”: “"${!csvReadStatus}" == "OK"”,
“Target”: “https://www.”,
“Command”: “echo”,
“Target”: “Status = ${!col1}, line = ${!csvReadLineNumber}”,
“Command”: “type”,
“Target”: “id=MainContentPlaceHolder_DownloadRegister_txtEmailAddress”,
“Value”: “${!COL1}”
“Command”: “select”,
“Target”: “id=MainContentPlaceHolder_DownloadRegister_rptQuestions_Responses_0”,
“Value”: “${!COL2}”
“Target”: “id=MainContentPlaceHolder_DownloadRegister_rptQuestions_Responses_1”,
“Value”: “${!COL3}”
“Target”: “link=Download”,
“Command”: “storeEval”,
“Target”: “${!csvReadLineNumber}+1”,
“Value”: “!csvReadLineNumber”
“Target”: “true”,
“Value”: “!errorIgnore”
“Command”: “echo”,
“Target”: "Reading CSV line No. ${!csvReadLineNumber} ",
“Command”: “endWhile”,
“Target”: “”,
