Why is macro giving error = [error]
Unclosed ‘if_v2’ (at command #10)
“Name”: “test2”,
“CreationDate”: “2019-11-15”,
“Target”: “xpath=//[@id=“div_field_ep_”]/div/button",
“Command”: “type”,
“Target”: "xpath=//[@id=“div_field_ep_”]/div/ul/li[2]/a/label/input”,
“Target”: “xpath=//[@id=“div_field_”]/div/button",
“Command”: “verifyElementNotPresent”,
“Target”: "xpath=//[@id=\“div_field_\”]/div/ul/li[42]/a/label”,
“Command”: “if_v2”,
“Target”: “”,
“Command”: “type”,
“Target”: “xpath=//[@id=“div_field_”]/div/ul/li[42]/a/label/input",
“Value”: “106”
“Target”: "xpath=//[@id=“div_field_”]/div/ul/li[42]/a/label”,
“Command”: “else”,
“Target”: “”,
“Target”: “xpath=//[@id=\“div_field_”,
“Command”: “if_v2”,
“Target”: “”,
“Command”: “type”,
“Target”: "xpath=//[@id=“div_field_”]/div/ul/li[113]/a/label/input”,
“Value”: “107”
“Target”: “xpath=//*[@id=“div_field_”]/div/ul/li[113]/a/label”,
“Command”: “else”,
“Target”: “”,
“Command”: “selectWindow”,
“Target”: “tab=1”,
