I got an Error: Failed to load c:\uivision\macros\SimpleRPA when I run SimpleRPA from PowerShell command line. Write-Host "Url="file:///C:/uivision/ui.vision.html?storage=xfile&folder=C:\uivision\macros\SimpleRPA&direct=1&closeRPA=1&closeBrowser=1&savelog=C:\uivision\logs\log_02-10-2022.txt
The same PowerShell command line script is working on other machines. If I load SimpleRPA macro without closing RPA, it works.
Please help.
thank you.
