Hi, guys.
I’m having continiously this error, sometimes when I execute the macro via html via .bat.
FROM THIS PAGE
[kantu]until: panel ipc expired!
ok
Any ideas of the reason of this? any suggestions?
Thank you all very much!!
Hi, guys.
FROM THIS PAGE
ok
Ouch, that should not happen. Some questions:
Of Course.
“C:\Users\Administrator\Desktop\G65\chrome.exe” “file:///C:\Users\Administrator\Desktop\G65\Macro.html?direct=1”
Nothing fancy. It happens in all of them (all have the same command, in several bats).
I have some bats with variations of that code, that triggers the html, and then several portable chromes open and start running the macros. I reboot the pc the erase cache and for other reasons, and when the pc starts, triggers the bats, > html> macros with chromes.
Thats when the error occur.
hello all,
I’m facing the same issue, but in my case, it only occurs when I try to run the macro at the first time after turn on/reboot the system. If I close the message and try to rerun the script again, it works, but if I need to reboot the system or turn off/turn on it, the first time always fail.
Any thoughts on how to solve it?
IPC issues are fixed with Kantu V3.1.6
